Expanding RAID volume on NAS326 is not working
Hi. Thanks for the advices. I manage to edit and save the file, but for some reason I'm not able to login over telnet after "power off" command. Any further help is highly welcome.0
User mistake as usual. Managed to telnet and got the system to work with expansion. Thank you Mijzelf!0
Got it working replacing my 2x4TB drives with two new 2x10TB drives.
Maybe some steps can be skipped, but for good measure I'm going to show everything I did.- Removed one of the HHD:s from the NAS and inserted a new HDD in it's place. In the admin-panel (//NAS326) I could see the progress. It took roughly 8 hours.
- Repeated with second disk. Kept the old disks safe in case of failure.
- Enabled SSH (and Telnet just in case) on the NAS using the admin-panel.
- Installed Putty.
- Inserted NAS IP (without any prefix), Port 22 and Connection type: SSH in Putty. IP can be found in admin-panel --> Control Panel.
- Loged in with the admin account in the command window that poped up.
- Typed "su" and had to provide admin password again.
- Pasted and ran "vi /etc/init.d/rc.shutdown".
- Pressed "i" on keyboard.
- Looked for "#swapoff" and pasted theses lines after that line:
/sbin/telnetd
/bin/sh - Pressed ESC-key and then typed and ran ":wq".
- Closed Putty.
- Opened Putty once again, using the same IP and Port, but select "Telnet" instead of "SSH" as Connection type. A new command window opened and I had to login again. I propably ran step 7. again.
- Pasted and ran "umount /i-data/sysvol"
- Pasted and ran "e2fsck -f /dev/md2". Action took a few minutes.
- Pasted and ran "resize2fs /dev/md2". This action took a while longer.
- Pasted and ran "killall -9 /bin/sh".
- Restarted NAS by pressing the physical power button.
- Loged in to the admin panel and could confirm resize. Disabled "SSH" and "Telnet" again.
- Made 10 cheers for Mijzelf and Gunslinger.
Hello Guys!
Unfortunately the steps written above are not working for my 326. I had 2 pcs 1TB discs (WD10EFRX) in Raid1 in my NAS, and want to change them to bigger ones, and have bought 2 pcs 6 TB (WD red WD60EFAX). The vi editing function can be done, but during telnet the umount is not allowed by system. Can this be because of the new firmware for example (I have the last existing installed approx 1 month ago)? Thanks for your kind help!0 -
I cannot imagine the firmware changed at this point. You were able to find that '#swapoff'?What processes are running at that moment? Run 'ps'.0
Dear Mijzelf,It was done as it was in the comment of Joonas, found swapoff also, entered the mentioned things.ps was like this:PID USER VSZ STAT COMMAND1 root 2648 S {init} /bin/sh -x /init
2 root 0 SW [kthreadd]
3 root 0 SW [ksoftirqd/0]
5 root 0 SW< [kworker/0:0H]
7 root 0 SW< [khelper]
8 root 0 SW [kdevtmpfs]
260 root 0 SW< [writeback]
262 root 0 SW< [bioset]
264 root 0 SW< [kblockd]
265 root 0 SW< [button controll]
266 root 0 SW< [mcu controller]
278 root 0 SW< [ata_sff]
288 root 0 SW [khubd]
296 root 0 SW< [md]
305 root 0 SW< [cfg80211]
391 root 0 SW< [rpciod]
396 root 0 SW [kswapd0]
397 root 0 SW [fsnotify_mark]
398 root 0 SW< [nfsiod]
399 root 0 SW< [cifsiod]
401 root 0 SW< [bioset]
403 root 0 SW< [crypto]
418 root 0 SW [ocf_0]
419 root 0 SW [ocf_ret_0]
1003 root 0 SW< [harddrive_hdd]
1015 root 0 SW [scsi_eh_0]
1018 root 0 SW [scsi_eh_1]
1063 root 0 SW [spi0]
1118 root 0 SW< [kpsmoused]
1135 root 0 SW< [kcryptd]
1154 root 0 SW< [deferwq]
1300 root 2648 S {linuxrc} init
1333 root 0 SW< [kworker/0:1H]
1379 root 0 SW [ubi_bgt4d]
1437 root 0 SW< [bioset]
1438 root 0 SW [md0_raid1]
1449 root 0 SW< [bioset]
1450 root 0 SW [md1_raid1]
1529 root 0 SW [jbd2/md0-8]
1530 root 0 SW< [ext4-dio-unwrit]
1553 root 0 SW< [loop0]
1554 root 0 SW< [ext4-dio-unwrit]
1573 root 0 SW [ubi_bgt2d]
1577 root 0 SW [ubifs_bgt2_0]
1622 root 3696 S /usr/sbin/zylogd
1632 root 6000 S /usr/sbin/uamd
1642 root 3808 S N /usr/sbin/cupsd
1669 root 133m S python /usr/local/apache/web_framework/main_wsgi.pyc
1838 root 0 SW< [bioset]
1839 root 0 SW [md2_raid1]
1868 root 0 SW [jbd2/md2-8]
1869 root 0 SW< [ext4-dio-unwrit]
1950 root 106m S N /usr/sbin/dservice
2005 root 1828 S N /usr/local/dmsf/binary/twonkystarter -appdata /i-dat
2008 root 20652 S N /usr/local/dmsf/binary/twonkyserver -appdata /i-data
2058 root 2648 S /bin/sh -c /usr/sbin/zylogger -r
2059 root 3368 S /usr/sbin/syslog-ng
2062 root 3692 S /usr/sbin/zylogger -r
2571 root 20700 S N pure-ftpd (SERVER)
2609 root 9880 S /i-data/.system/zy-pkgs/pkg_httpd -f /etc/pkg_servic
2803 root 136m S {transmission-da} /i-data/c590a559/.PKG/Transmission
2816 nobody 11452 S /i-data/.system/zy-pkgs/pkg_httpd -f /etc/pkg_servic
2817 nobody 11452 S /i-data/.system/zy-pkgs/pkg_httpd -f /etc/pkg_servic
2910 root 2648 S {xmpp_client_mon} /bin/sh /i-data/c590a559/.PKG/myZy
3024 root 12108 S N {zyxel_thumb_cre} /i-data/c590a559/.PKG/myZyXELcloud
3064 root 5264 S {zyxel_file_moni} /i-data/c590a559/.PKG/myZyXELcloud
3068 root 25272 S N /usr/sbin/smbd -D
3075 root 25280 S N /usr/sbin/smbd -D
3076 root 17236 S N /usr/sbin/nmbd -D
3080 root 20340 S < /usr/sbin/nsuagent
3135 root 2680 S N avahi-daemon: running [NAS.local]
3184 root 1684 S /usr/sbin/myhotplug
3189 root 1684 S N /usr/local/btn/do_btncpy
3219 root 1752 S /usr/sbin/hd-idle -i 1800
3286 root 4152 S N /usr/sbin/netatalk -F /etc/netatalk/afp.conf
3345 root 5908 S N /usr/sbin/afpd -d -F /etc/netatalk/afp.conf
3350 root 4312 S N /usr/sbin/cnid_metad -d -F /etc/netatalk/afp.conf
3585 root 17656 S python /usr/local/apache/web_framework/job_queue_dae
3588 root 2788 S N /usr/sbin/app_wd
3596 root 1764 S N /bin/lld2d egiga0
3653 root 10424 S /sbin/DAV_httpd -f /etc/service_conf/httpd_dav.conf
3690 root 3664 S zysync --daemon --config /etc/zysyncd.conf --log-fil
3716 root 3780 S stunnel /etc/stunneld.conf
3747 root 12044 S /sbin/DAV_httpd -f /etc/service_conf/httpd_dav.conf
3748 root 12044 S /sbin/DAV_httpd -f /etc/service_conf/httpd_dav.conf
3779 root 0 SW< [target_completi]
3780 root 0 SW< [tmr-rd_mcp]
3803 root 0 SW [iscsi_ttx]
3804 root 0 SW [iscsi_trx]
3805 root 0 SW [iscsi_ttx]
3806 root 0 SW [iscsi_trx]
3807 root 0 SW [iscsi_ttx]
3808 root 0 SW [iscsi_trx]
3809 root 0 SW [iscsi_ttx]
3810 root 0 SW [iscsi_trx]
3838 root 1680 S /sbin/ipnotify -d -s -r /sbin/ipnotify_exec.sh
3899 root 106m S N python /usr/local/fileye/fileye.pyc
3908 root 2648 S /bin/ifplugd -a -p -q -t3 -d0 -u0 -i egiga0 -r /sbin
3929 root 2008 S /sbin/mdadm --monitor -p /usr/sbin/mdadmstatuslog.sh
3996 root 9892 S N /usr/sbin/httpd -f /etc/service_conf/httpd.conf
4045 root 2880 S {zyxel_enet_brid} /i-data/c590a559/.PKG/myZyXELcloud
4053 root 2648 S {linuxrc} init
4654 root 15564 S {zyxel_xmpp_clie} /i-data/c590a559/.PKG/myZyXELcloud
7424 nobody 22092 S N /usr/sbin/httpd -f /etc/service_conf/httpd.conf
7497 nobody 22348 S N /usr/sbin/httpd -f /etc/service_conf/httpd.conf
7498 nobody 22092 S N /usr/sbin/httpd -f /etc/service_conf/httpd.conf
7515 nobody 22096 S N /usr/sbin/httpd -f /etc/service_conf/httpd.conf
7726 nobody 11540 S N /usr/sbin/httpd -f /etc/service_conf/httpd.conf
7769 root 0 SW [kworker/u2:1]
7804 root 2648 S /sbin/telnetd
7807 root 4592 S /sbin/sshd -f /etc/ssh/sshd_config
7904 root 0 SW [kworker/u2:2]
8831 root 4592 S {sshd} sshd: admin@pts/0
8854 admin 2760 S -sh
8866 root 2760 S sh
8895 root 0 Z N [sh]
8962 root 2516 S sleep 10
8979 root 2760 R ps
9349 root 5280 S N /usr/bin/schedule_controller
9350 root 1544 S N /usr/bin/timer_source
13275 root 0 SW [kworker/0:2]
20199 root 0 SW [kworker/0:0]
27026 root 25604 S N /usr/sbin/smbd -D
27435 root 0 SW [kworker/u2:0]
27699 root 2756 S N /sbin/crond -L /dev/nullDuring the umount I have the following message:~ # umount /i-data/sysvol
umount: /i-data/c590a559: target is busy
(In some cases useful info about processes that
use the device is found by lsof(8) or fuser(1).)
You have lots of daemons still running. Joonas list has one fatal flaw. After point 11 'enter :wq' you should run 'poweroff' to initiate the shutdown.
Dear Mijzelf,Thanks!As I don't know too much about Linux, may I ask you, what do you mean "After point 11 'enter :wq' you should run 'poweroff' to initiate the shutdown." As I understand: after exiting the vi, should I run the "poweroff" function? Sorry to ask you stupid things.
The script /etc/init.d/rc.shutdown is used by the firmware to stop all processes and unmount the data partitions before powering off or restarting the box. What we do is putting some extra code in that script to get telnet access after the script has cleaned up the air. The ':wq' command exits vi, so that is the moment the script is prepared.Now you have to shutdown the box to get the script running, which can be done by executing 'poweroff', or by the webinterface.
Dear Mijzelf,It was running, thanks!Attila0
- 415 Beta Program
- 2.4K Nebula
- 152 Nebula Ideas
- 100 Nebula Status and Incidents
- 5.8K Security
- 289 USG FLEX H Series
- 278 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 252 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 75 Security Highlight
