Problems changing admin password NAS540
alexpe
alexpe Posts: 42  Freshman Member
edited March 2020 in Personal Cloud Storage
I have changed the admin password of a NAS540. Now I can not enter through the web but if it allows access by SSH and SMB. How can I recover web access?
#NAS_Mar_2020
  • alexpe
    Can you confirm that if I reset it I won't lose all the information?
  • alexpe
    other question, Is it possible to update the firmware by SSH to correct the problem?
  • Mijzelf
    Mijzelf Posts: 2,940  Guru Member
    You misunderstood me. I think your firmware is already upgraded, and that your password contains one of the now forbidden characters. Then you can't login in the webinterface anymore.
    And yes, if you reset until the first beep, it only resets the admin password and sets the network to DHCP client.
  • Martull
    Martull Posts: 6  Freshman Member
    Hello, It has happened to me the same, not being able to log in via Web but been able via ssh.
    I logged in with a different user, logged out, and then I was able to logged in with the admin account again.
    HIH
  • Dexter
    Dexter Posts: 108  Ally Member
    edited December 2021
    Have you ever try to reset the NAS?
    After reset, does it should work?
