NAS326 after firmware update SSH works HTTP does not, phone APP HTTPS doesn't work either.
laz954
I saw many messages about clearing cache, etc. This is not the issue, it looks like HTTPS was disabled after firmware upgrade, SSH is functional with admin/password but HTTPS is being rejected. Phone APP also rejects HTTPS login, can you ssh to the device and enable HTTPS functionality or is there another workaround using SSH or any other method ?
#NAS_Mar_2020
Checked item 2 from below link.
https://homeforum.zyxel.com/discussion/3370/faq-upgrading-latest-nas-remote-code-execution-vulnerability-firmware#latest
how to disable ssh with password and enable with public key?whenever i try to set with public key, return to authentication with password0
As far as I know, Zyxel NAS doesn't support public key for SSH.1
- 6.8K All Categories
- 1.3K Nebula
- 26 Nebula Ideas
- 28 Nebula Status and Incidents
- 3.8K Security
- 199 Security Ideas
- 691 Switch
- 25 Switch Ideas
- 572 WirelessLAN
- 8 WLAN Ideas
- 4.5K Consumer Product
- 95 Service & License
- 213 New and Release
- 35 Security Advisories
- 479 FAQ
- 216 Nebula FAQ
- 109 Security FAQ
- 72 Switch FAQ
- 66 WirelessLAN FAQ
- Documents
- 20 Nebula Monthly Express
- 42 About Community
- 31 Security Highlight
