How to enable Samba log
After reboot NAS I was checked /tmp/Tweaks.log. All daemons was started. But adding "touch /tmp/${PKG_NAME}.log" to line 337 gives me 500 error at http://NAS/pkg/Tweaks/pkgcgi.cgi.Delete that line and rebbot NAS.If I stop samba (/etc/init.d/samba.sh stop), samba continue working. If I restart samba (/etc/init.d/samba.sh restart), samba continue working without --configfile=/etc/samba/smb.conf.Tweaks.Any ideas?0
Have you checked if samba.sh is patched?
grep Tweaks /etc/init.d/samba.sh
gives me 500 errorThat's a syntaxerror in the script. pkgcgi.cgi sources init.d/Tweaks when the webinterface is called. You can check for syntaxerrors withsh /i-data/sysvol/.PKG/Tweaks/etc/init.d/Tweaksit should run without errors (without any output at all, actually.The lines around the adaption should be something like
chown root:nobody ${TWEAKS_CONFFILE}
chmod 660 ${TWEAKS_CONFFILE}
Log "Deamon load plugins"
Yes, of course. /etc/init.d/samba.sh was patched.touch /tmp/${PKG_NAME}.log run with errors.Only reinstall get effect.0
And after another reboot of nas there only one way to use Samba Tweaks - reinstall it. What should I check additionally?
I really don't know. On my box I can see in top that the different config file is applied. And I don't see how reinstalling would do something different than dis- and enabling Tweaks or dis- and enabling this specific Tweak.Unless you have something strange in your custom smb.conf, causing side effects.0
- 588 USG FLEX H Series
- 476 News and Release
