Nas326 transmission config
pikehunter
Hello
Transmission saves the downloaded files in the admin folder.
There is a wish to adjust preservation in the new, separate folder, for example share. How to make it?
#NAS_Dec_2018
You should only edit the settings.json file with transmission disabled.
I founded /i-data/.../.PKG/Transmission/.../config/settings.json , but after enable/disable transmission my chages are lost.
Make remote call periodically
transmission-remote nas -w "/i-data/470f7598/video"
it works for me.
- 588 USG FLEX H Series
- 476 News and Release
