I have an NSA 325 V2. Is it time to upgrade to a newer NAS?
davidchef
My NSA 325 V2 is getting a bit old now and is no longer supported by Zyxel and a couple of things such as saving to googledrive are no longer supported. Should I cut my losses and move to a new NAS and if I do is it a simple task to move my drive into the new NAS and will it work?
#NAS_Mar_2020
#NAS_Mar_2020
If you unplug NSA325v2's disk and plug it to new NAS device, it may not work due to different file system format.
You can backup data in somewhere, and then copy it to new NAS device.
Or using backup feature of NSA325v5 to backup data to new NAS device.0
- 603 USG FLEX H Series
- 480 News and Release
