Multy X - Sky Q Connection Issue
zendot
Hi... My main Sky Q box keeps disconnecting from my Multy X network, multiple times a day every day for an hour or more at a time. I’ve had my Multy X network since November 2018 and Sky Q since March 2017, and didn’t have any problems until about two weeks ago when some redecoration work required me to unplug the Multy X units several times. I have three Multy X units and two Sky mini boxes in addition to my main Sky Q box. These don’t work either, of course, as they rely on the main box. Does anyone have any thoughts or suggestions? Thanks.
#MultyX_Apr_2020
#MultyX_Apr_2020
Dear Sir,
1. What is your Network topology? How do you connect your Sky Q boxes to Multy?
2. Have you tried to change the Ethernet cable which connects to the SkyQ Box?
3. Did those Multys ever glow red after the redecoration?
4. Do other devices which connected to Multy have a similar issue that disconnects consistently?
5. Please "Send Feedback" from your Multy App, we will check your log to clarify this issue.
Best Regards,
Eric0 -
Many thanks for getting back to me, Eric.
I’m in the UK. My ISP is Zen. I connect to them via FTTC and copper wire to a BT Openreach socket and modem, which is Ethernet-wired to my primary Multy. The other two Multys are connected wirelessly to this primary one. Everything in the house is then connected wirelessly to this network, including the main Sky Q box. The two Sky mini boxes are connected to the main box, one via a Sky-supplied booster, using Sky’s own mesh network.
As above, there isn’t one. I bought a 30 metre Ethernet cable yesterday, which should arrive tomorrow, to try connecting the main Sky Q box directly to the primary Multy. This is to see if I can isolate the problem to a communication issue between the two.
I’ve only ever noticed them glowing red when I restart them. I’ve taken to restarting the primary Multy, then each of the other two, from time to time.
Not that I’ve noticed. We generally have 15-20 devices connected, the usual mix of computers, phones, TVs, SONOS speakers, etc.
Will do. Thanks again.0 -
Hi Eric... Have you had a chance to look at my note above and/or my “Send Feedback” log? Any help would be great. Thanks.0
Dear Sir,
We have received your feedback. We will assist you via email.
Best Regards,
Eric
- 588 USG FLEX H Series
- 477 News and Release
