Name file of nas is different on Smart tv?
emau74
emau74 Posts: 53 image  Ally Member
Friend Collector Third Anniversary
edited November 2019 in Personal Cloud Storage
why the name of the file of the nas is not similar to what I see on the multimedia player of my samsung tv?
(example name of nas yyyyyyyyzzzzzzz.mkv on my tv is zzzzzzzz.mkv.
#NAS_Nov_2019
  • JockeSve
    JockeSve Posts: 82 image  Ally Member
    edited November 2019 Answer ✓
    Below script takes all mkv files in the current directory and sets the filename as the mkv-file title.
    Requires installation of MKVToolNix.
    I'm using Kodi compatible naming for all movies, I.e. <moviename> (year).mkv. ( It Chapter Two (2019).mkv ) and it works flawlessly.
    <div>@ Echo Off&nbsp;
    &nbsp;
    </div><div>for %%f in (*.mkv) do (
    &nbsp; &nbsp; echo Replacing movie title:&nbsp; %%~nf
    &nbsp; &nbsp; "C:\Program Files\MKVToolNix\mkvpropedit.exe" "%%~nf.mkv" -e info -s title="%%~nf"
    )</div>
«1
  • JockeSve
    Some TV and media players does use the file 'Title' instead of the file name.
    AFAIK does at least MKV container and MP4 support 'Title'.
  • emau74
    how do I change the title tag in a mkv file directly in the nas?
  • JockeSve
    I'm using a tool for that: MKVToolNix (https://mkvtoolnix.download/index.html)
    It's pretty simple to re-encode MKV's with correct tags from the filenames.
  • JockeSve
    &nbsp;
    )</div>
  • emau74
    edited April 2020
    first of all thank you for the reply; so how should I do to change the title of my files located on the nas (x:)?
    thanks
  • JockeSve
    edited April 2020
    I did that in two steps;
    1. Changed filenames according to KODI naming conventions. I.e "Movie name (year)"
        Like: "Lady and the Tramp (2019)"
    2. Run a script that set's correct title-tag in all MKV-files.
    <div>@ Echo Off
    </div><div>REM This script takes all mkv files in the current directory and sets the filename as file title.
    </div><div>&nbsp; &nbsp; echo Adding/replacing movie title:&nbsp; %%~nf&nbsp;
    &nbsp; &nbsp; "C:\Program Files\MKVToolNix\mkvpropedit.exe" "%%~nf.mkv" -e info -s title="%%~nf.mkv"
    </div><div>)</div><div></div>
    Note: This works for MKV's only as 99% of my movies & series are MKV
  • emau74
    I did as you advised me but now on the smart TV in the folders of the nas no film is recognized, how come?
  • JockeSve
    How does a PC and/or tablet (cellphone) show names and file tags?
  • emau74
    on the pc or from android in the folders of the nas the names are there
    but the strange thing is this
    twonky server no longer sees shared folders
  • JockeSve
    When it comes to Twonky, I have no idea. Never used it...
    As long as file name matches the title tag and files are playable (PC, tablet, ...) that part is OK.
