Can't log in to XMG3927-B50A Router
Fleagle
Had a new router installed yesterday and went to log in to change the password etc.
I get to the log in page and enter the details as per the instruction card ie admin and password.
Unfortunately it always comes back with "Setting not successful. Please try again" it sometimes shows a further message "unauthorised 401".
The login details have been entered correctly as per the instructions, I have also tried
Nothing seems to work so any ideas?
Fleagle
#SP_Apr_2020
- Switching on and off
- Full factory reset
- Login in from different devices ie mac, window,s PC's iPad, iPhone etc
- Disabled any pop up blockers antivirus etc
- Hardwired to router
Fleagle
#SP_Apr_2020
@Fleagle,Do you mean you reset the router and then use the admin/password shown on the label of the router but you failed to log in?If you used to change the router's password, you should use the new password to log in. If you reset the router, then you should use the default password.0
Yes I reset the router went to enter the original default admin login and password, the password is a 8 letter/digit code and it won't let me. As it's a new router the login details have never been changed from the original details.
I've tried different laptops, phones, iPads to log in reset everything switched of antivirus, deleted history, cache etc rebooted laptops etc but nothing.0 -
That was my next course of action unless someone had pointed out some glaring error on my part!0
- 429 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 350 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
