i keep trying to login into my router but it says i've used the wrong username and password. Please
Fargo BabyBoii Flame
Login Problems
@Fargo BabyBoii Flame
What's your home router's model name? Did you push reset button before entering login credentials?
You can search for your model's "User's Guide" on our global website, where default admin/password is put in the first page.
(https://www.zyxel.com/products_services/home-home_routers.shtml?t=c)
Best Regards,
Richard0 -
I have exactly the same problem. The model is Zyxel VMG3625-T50B. I tried to reset the modem, I was able to access the console with default username (admin) and password (found on the back of the device), then I was prompted to change the password. I changed it and copied it to a separated file, so no writting error is possible. After log off, I was not able to log on again. I just got this boring message: " The username or password is not correct or locked. "
Please, help!
i dont remember ever resetting my password but the default login credentials dont work. i dont want to have to reset my router
any help would be great! :)
any solution for admin account lock after reset
- 588 USG FLEX H Series
- 476 News and Release
