NAS326: Unable to find any UPnP supported routers
Emerald Dragon
When I go into my NAS326 control panel under UPnP Port Mapping It said "Unable to find any UPnP supported routers". But when I check my router, UPnP is turn on. Not sure what else to do. BTW, I have Google Wifi Router.
I've also run into some issues about upnp setting.
On router, my workaround is to use NAT to direct the port (like 80 for http) via port forwarding to the NAS.
It's rather simple and easy!
I think I tried that port forwarding but it didn't work for some reason. I am working with Google Wifi Router and it seems to not understanding.0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
