Nas 326 Login Problem after update
Sdeede
Hi!
Like it says after update the latest firmware v 5.21(AAZF.8)CO i can no longer login to my zyxel. It works with cyberduck to access it and from the regular network but not from the login page.
It says wrong user/password. But works on cyberduck. Does someone know the problem?
Does your password include special characters?
If the password does include those characters, you will have to reset the password. You can refer to this post.
https://homeforum.zyxel.com/discussion/3370/faq-upgrading-latest-nas-remote-code-execution-vulnerability-firmware#latest1
https://homeforum.zyxel.com/discussion/3370/faq-upgrading-latest-nas-remote-code-execution-vulnerability-firmware#latest1 -
Do a reset and log in with Admin/1234.1
Thx guys that did it
thank zYXEL FOR DISTROYING 2 NASSES AFTER UPDATE MANY THANKS0
RESET DOES NOT WORK SO ,,,why not tested the update before you distroy every nas326
It need to change the password before update to the firmware, you can refer to this topic.
https://community.zyxel.com/en/discussion/8525/faq-upgrading-latest-nas-remote-code-execution-vulnerability-firmware/p1
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
