PLEX on NAS542
You can find your shares in /i-data/<some-long-hex-name>/
Hi all,
I have a problem with the last step. When I install plex server in the nas, I don't have any problem, but plex ask me for user (I have a user in plex some years ago), I select this user but I cannot select my nas, it doesn't appear.... What am I doing bad?
Thanks in advance
Hi Friend,I have the same problem as you.My divice is NAS542.Was your divice (NAS542) on based setting before the installation of web_prefix file?Was your admin folder empty?My problem is, I saved the web_prefix to the right place (\\<NAS\admin\) but in spite of this after refreshing the App Center there is no MetaRepository aplication avaiable.
I have done everything as described.I would be grateful for any idea or suggestion.Thank you in advance and take care!0 -
@NAGROBE, you have to create the folder "zy-pkgs" and upload the web_prefix file there in order for it to work.
\\NAS\Admin\zy-pkgs\0 -
@NAGROBE, How did you downloaded the web_prefix file? Did you right-click and download it from the site?0
@Emerald Dragon Yes, right-click and 'save as' to the right folder and there is no extension, only simple file.
- 441 Beta Program
- 210 Nebula Ideas
- 540 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
