ssh loginless connection security
Andras
Hi Guys,
Finally I could change the root's home dir using Twonky. Than I re-started to generate the key pair for passwordless login from my openhab server. It went well, key got copied to my nas. Hoever the ssh from the openhab keep asking password. Than applied chmod 700 for the .ssh and chmod 640 for the .ssh/authorized_keys but still no success.
What is also interesteing that the ssh root@[nas ip] cd .ssh also not works. It does not let me to enter to the folder even typing the password.
So I guess the problem is with some security setup on my NAS.
Idea how to change it?
What is the output of[code]pwdls -la[/code]after logging in as root?0
Hi Mijzelf,
I see this:root@NSA310:~# pwd/i-data/md0/adminroot@NSA310:~# ls -latotal 206300drwxrwxrwx 10 root root 4096 Apr 13 09:42 .drwxrwxrwx 13 root root 4096 Apr 13 09:42 ..-rw------- 1 root root 480 Apr 13 19:24 .bash_historydrwx------ 2 root root 4096 Apr 13 12:49 .ssh...root@NSA310:~# ls .ssh -latotal 12drwx------ 2 root root 4096 Apr 13 12:49 .drwxrwxrwx 10 root root 4096 Apr 13 09:42 ..-rw------- 1 root root 744 Apr 13 12:49 authorized_keys
"/i-data/md0/admin" what I set in Tweaks
DRWX codes looks equivalen with the desired chmod codes (700 for .ssh and 640)0 -
authorized_key does not have permission 640, this is 600. 640 is -rw-r-------. Yet I don't know if that is a problem.You have a NSA310, so I assume you are using the dropbear package for ssh? That package is rather old, version 2014.63. Maybe it doesn't support the keypair you generated. You can try to use the provided dropbearkey (/usr/local/zy-pkgs/bin/dropbearkey) to generate your keypair.0
Changed to 600 but no success
I use OpenSSL:root@NSA310:~# ssh -VOpenSSH_5.9p1, OpenSSL 1.0.0e 6 Sep 20110 -
Well, that one is even older. So if you created your key pair on another box, odds are that it's not compatible anymore.BTW, have you tried to login using 'ssh -vvv' to get more info?0
Do you have any suggestion hpw to upgrade it?
This is what I can see:root@NSA310:~# ssh -vvvOpenSSH_5.9p1, OpenSSL 1.0.0e 6 Sep 2011usage: ssh [-1246AaCfgKkMNnqsTtVvXxYy] [-b bind_address] [-c cipher_spec][-D [bind_address:]port] [-e escape_char] [-F configfile][-I pkcs11] [-i identity_file][-L [bind_address:]port:host:hostport][-l login_name] [-m mac_spec] [-O ctl_cmd] [-o option] [-p port][-R [bind_address:]port:host:hostport] [-S ctl_path][-W host:port] [-w local_tun[:remote_tun]][user@]hostname [command]
Do you have any suggestion hpw to upgrade it?You could use the ssh server from Entware-ngThis is what I can see:That is not what I meant. If you on the other box executessh -vvv root@nsa310you might see why the key login doesn't work.
- 435 Beta Program
- 176 Nebula Ideas
- 120 Nebula Status and Incidents
- 434 USG FLEX H Series
- 299 Security Ideas
- 80 Switch Ideas
- 276 Service & License
- 428 News and Release
- 89 Security Highlight
