PLA5456 both ports connected causes loop?
Crion
I just purchased a PLA5456 set and I'm having some issues with setup. I'm attempting to connect two devices in the remote room to the local adapter. I'm operating under the assumption that I need both ports on the local adapter connected to my router to transmit to the two ports on the remote adapter but every time I plug both in, my internet connection drops out on my desktop which is directly connected to the router. I'm guessing that connecting both ports is causing a loop. Is the expected setup for two ports to use a single port on the local side? If so, that really should be in the quick start guide.
#PLA_Apr_2020
#PLA_Apr_2020
Hi, @Crion
Thanks for sharing your user experience, and we're really sorry for causing your misunderstanding when setting up devices.
Like all other network devices, PLA is a way to delivery network connectivity to remote end-devices. With more Ethernet ports are provided, more devices can assess network without additional hubs/switches.
So when mounting our PLAs, just kindly take them as general hubs/switches, with merely one link to your home router is required (and two PLAs are connected through power-line).
For the suggestions of editing the Quick Start Guide, it will be discussed and evaluated internally. Sincerely thanks again for your feedback.
Best Regards,
Richard
Hi, @Crion
Best Regards,
Richard
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
