PLEX on NAS542
  • NAGROBE
    NAGROBE Posts: 12  Freshman Member
    @Mijzelf
    The ping  < zyxel.diskstation.eu/ > success
    The< zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/ > failed
  • Mijzelf
    Mijzelf Posts: 2,942  Guru Member
    That is normal. You can only ping domains (or IP addresses).
    In some way it's a pity you can ping zyxel.diskstation.eu. That means it's reachable for your NAS, which rules out the simple solutions.
    Next step is the logfile. You can find it in /i-data/sysvol/.system/zy-pkgs/zypkg.log. It's huge. Search for error messages in the neighborhood of the string 'zyxel.diskstation.eu'.
  • NAGROBE
    Welcome @Mijzelf
    So far I have not found the log files. The folder marked on the Syslog Server is empty.
    I think it would be better to do a SYSTEM RESET.
    I think the saved data is not deleted by RESET, is it?
  • NAGROBE
    The RESET was not succesfull either. Still can't find the MetaRepository after refreshing the App center. There are still no failed messages in Log report.
  • Mijzelf
    Enable the ssh server on your NAS, and use WinSCP to search for the logfile.
  • NAGROBE
    Hy @Mijzelf
    I'd like to thank you for your all support and time! It was understandable at the first time what to do. In spite of this, I still can't go through to this step.
    The SSH service was accept but the /i-data/sysvol/.system/zy-pkgs/zypkg.log. patch is does not exist.
    I set up the patch to the SYS log server but I still can't find log file in this folder.
    I am so sorry to bother you many times, I'm pretty sure that I did something wrong.
  • Mijzelf
    Files (and directories) starting with a . are considered 'hidden' in Linux. So you have to tell WinScp to show hidden files:
  • NAGROBE
    @Mijzelf
    The setting was OK.
    The error was not resolved even after a system reset.
    Do I need to remove the HDD before resetting the system?
  • Plex on NAS542
    Plex on NAS542 Posts: 19  Freshman Member
    Hi All,
    I have a lot of problem for reproduce the sound DTS 5.1 in my NAS542 with plex. Some movies run but another ones no. How could be fixed?
  • Mijzelf
    I think you'd rather ask this in a Plex forum.
