Daylight-saving-time offset not at the defined time?
This weekend the daylight saving time became active and the USG has switched its time. Our settings are: switch the time on last sunday in March at 2:00, offset 1 h.
But the log diagrams (see e.g. session log below) show an offset between 00:00 and 01:00 a clock but not from 02:00 to 03:00.
@USG_User
I tested it locally without any issue. You may check the time on the log diagram immediately after you configured daylight saving time.
From my daylight-saving settings where you can see that the USG should add 1 hour offset at 17:35. On the log diagrams show the time was modified to daylight-saving time.
Time Offset
Charlie0 -
Thanks for your effort. I try to repeat a daylight saving during next days. Unfortunately this is our production system where I'm not able to do special tests during office hours. I come through again when I have new results.
Joerg
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
