PLEX on NAS542
  • Plex on NAS542
    Plex on NAS542 Posts: 19 image  Freshman Member
    A Plex Forum on this community?
  • Emerald Dragon
    Emerald Dragon Posts: 120 image  Ally Member
    No, on Plex.tv site
  • DeathNote
    DeathNote Posts: 4 image  Freshman Member
    Zyxel Certified Network Administrator - Security First Anniversary
    Hi all.
    I dont have any metarepository in app list.
    Yes i click button refresh list !
  • Mijzelf
    Mijzelf Posts: 3,023 image  Guru Member
    web_prefix shouldn't have an extension.
  • DeathNote
    thnks, work
  • mzcrt
    mzcrt Posts: 6
    Hello. I get an error like this on the plex installation screen, I cannot install. I would appreciate it if you can help me greetings.
  • Mijzelf
    Long shot, is your disk full?
  • mzcrt
    mzcrt Posts: 6
    No, it's not.
  • Mijzelf
    edited June 2024
    According to your screenshot you are uploading a Synology package. The code used to extract that is:
    echo -ne "Try to untar..."
    mkdir -p "${tmpdir}/synology"
    tar xf "${plexfile}" -C "${tmpdir}/synology"
    if [ $? -eq 0 ] ; then
    echo "Done"
    [ ! -f "${tmpdir}/synology/package.tgz" ] && SetError "Unrecognized file" && return 1 echo Synology package detected echo -ne extracting.... tar xf "${tmpdir}/synology/package.tgz" -C "${tmpdir}/bin" [ $? -ne 0 ] && echo "Failed" && SetError "Cannot extract ${tmpdir}/synology/package.tgz" && return 1 echo "Done" fi
    Extracting the spk file succeeds, but extracting the internal package.tgz file fails. But it exists, else it would have spawned an "Unreconized file" error.
    You can login over ssh, try to upload again using the webinterface, and then run 'dmesg' in the ssh shell to see if there were any filesystem or hardware errors.
  • mzcrt
    mzcrt Posts: 6
    I'm sorry I'm not very good at this stuff. I don't know exactly what to do when I connect via SSH. do I copy and paste the code you give exactly. I connect via the web interface and I use it for backup purposes. if I install plex, I want my kids to watch the animations I have. I wish there was someone who could help with a remote connection. By the way I am using translation for english.
