Does NAS326 work with only one hard drive
maries
Can I use this NAS with only one hard drive and add a second only when I'll need it?
If I'll put the second one later, will have to reconfigurate the first one and loose all my files?
Do you intend to RAID for two HDDs? if no, just create a new volume on second one, the original one would be just fine.0
Ok thanks. I put a 4To Ironwolf hard disk inside and when I try to configurate the nas through the web findme.zyxel it just doesn't happen nothing ..... I can see the Nas from my computer but I can enter. What did I do wrong?0
You did nothing wrong. DNS didn't resolved and find your NAS326, I have the same problems with mine. It's something between your router and NAS326 not being compatible (working together) for some reason. So, automatic configuration won't works.
You'll have to do a manual configuration instead.0
- 588 USG FLEX H Series
- 476 News and Release
