VMG8825-T50 Firewall rules not working
mtn
Firewall ACL rules do not work. Endpoint is still available. What Am I doing wrong?
#SP_May_2020
@mtn,Can you describe it in detail? What do you mean "Endpoint is still available"?According to your rule, it seems like you want to block the LAN side IP 192.168.1.179 to access the WAN side 13.224.67.x subnet.
What is the real purpose for this firewall rule?0 -
@mtn,I ran a test to set the firewall to High without creating any rule and then I can't ping 13.224.67.1 immediately.Can you share your test steps? How do you verify that the Endpoint is still available?
Instead, when I set it to Medium, I can ping 13.224.67.1 correctly.
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
