after firmware update apps not working
Corwin
Hello
I have a nas540.
After the recommended firmware update to 5.21 and re-installation of transmission i can't get it work again.
I've tried to install tftp and nfs wit the same result:
just a button with launch and no action at all.
Somebody an idea what i'm doing wrong?
Can't find any file/directory for transmission or daemon or json (via winscp)
Also, no contact for automatic check for updating firmware
thx
I have a nas540.
thx
Can you refresh it in "All Apps"? you should be able to download the list.
If no, check your network setting (gateway, DNS).1 -
What was your previous firmware version? If that was <5.10, I think you have to remove all packages first, and then reinstall.
It's working now
put dns to automatic and disabled ipv6
and next removed packages
Thx both
- 237 Nebula Ideas
- 6.8K Security
- 741 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
