PLA5456 compatibility
cbz
cbz Posts: 2 image  Freshman Member
edited June 2020 in Smart Home Product
Hi - I’ve had a pair of pla5456 and one of them has now failed. Could you tell me what other devices will be compatible with this ? As I am having difficulties getting a replacement pair and want to get something with which I can continue to also use the remaining unit.
#PLA_May_2020
  • Greenlight
    Greenlight Posts: 57 image  Ally Member
    In my memory PLA5456 is compatible to all other Zyxel PLA products except PLA6456(which is used different pairing protocol).
  • cbz
    Is it backward compatible with older units?  Asking because it appears that I can't buy anything but the PLA6456 at the moment (nothing available via the retail channels).
  • Zyxel_Freda
    Zyxel_Freda Posts: 397 image  Zyxel Employee
    25 Answers First Comment Friend Collector Third Anniversary
    Hello @cbz ,
    The PLA5456 is compatible to below models for your reference.
    As @GreenLight replied, the PLA5456 is compatible to all other Zyxel PLA products except PLA6456 because of using different standards.The PLA5456 uses 'HomePlug AV2' and 'IEEE 1901 HomePlug AV'; the PLA6456 uses G.hn technology.
    As demand for ultra-fast Internet speed increases, G.hn technology is becoming the best in-home electrical network connection. Up to two times faster than HomePlug AV2 technology. Zyxel PLA6456 with G.hn technology delivers maximum data transfer rate and stability for your home networking.
    Hope it's helpful.
    Thanks.
  • owaisms
    owaisms Posts: 1 image  Freshman Member
    My question is not about upward or downward compatibility but using the four modules i.e. two pairs, one pair of Pla6456 and one pair of pla5456 on the same electrical power circuit. Is it permissible? Will it work?
  • ikubuf
    ikubuf Posts: 143 image  Ally Member
    If they are not using the same technology, pairing may not be possible. To resolve this, you can pair the same model on the same power extender. After pairing, you can place them on the same circuit
  • darrylwalsh
    darrylwalsh Posts: 3 image  Freshman Member
    Thanks for your answer. I got it.
