Carrier Aggregation ethernet LTE 4506
ayassino
Hi!
I have a LTE 4506 router, when I use ethernet port carrier aggregation is almost never activated, when I use the integrated wifi there are no problems. Why? Are there any solutions?
Thanks so much!
Ayassino
Thanks so much!
Ayassino
#SP_May_2020
Hi @Mia, thank you so much for the reply.
The first times I used it when I did a speed test it always went to CA, now it goes randomly, sometimes it works, sometimes it doesn't. Should I try to reset?
It is not a problem related to the telephone operator because it works on the smartphone.
Thanks so much!
Ayassino0 -
Hi ayassino , when user equipment reach enough downstream traffic whether activate CA its depend on provider network current situation. LTE router is a negative role it can't do anything for CA activated. So reset LTE router might not help. You can check LTE4506 GUI the signal level(Internet>Internet Status>Signal Level) if weak or not, then place LTE4506 to the good signal location to see if improve the problem.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
