FTP NAS326
William990
William990 Posts: 4 image  Freshman Member
Hi everyone, I have installed a Zyxel NAS model NAS326 with two 1TB HDDs in RAID1. Everything works perfectly the only thing is that I cannot access FTP from outside the network. From inside the network I reach it I enter username and password and it works normally while from outside the network using the public IP address I reach it but continues to always tell me incorrect login. Can anyone recommend any possible solution ?? Thanks so much.
  • ENDLESS
    ENDLESS Posts: 56 image  Ally Member
    Did you configure port forwarding on your router?
    What kind of software you use?
    Is there any log on it?
  • William990
    Sorry if I answer only now because of work. Yes I have configured port forwarding on my router, in fact I reach the NAS from the outside but it gives me login error. I use filezilla as an FTP client and no on the NAS in the logs I don't find anything related to the attempt to access. Any idea ??
  • ENDLESS
    Sorry for the unclear question, I mean the log on filezilla. Also, did you change FTP port on NAS? How you configure the port forwarding on your router? Any error code when login fail?
  • William990
    This is the log of Filezilla:
    Stato:    Connessione a 2.228.66.230:21...
    Stato:    Connessione stabilita, in attesa del messaggio di benvenuto...
    Stato:    Server non sicuro, non supporta FTP su TLS.
    Comando:    USER admin
    Risposta:    331 Password required for admin
    Comando:    PASS ************
    Risposta:    530 Login incorrect
    Errore:    Errore critico: Impossibile collegarsi al server
    I configure the port 23 with the internal IP of NAS. I think the error code is 530.
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    Long shot. That isn't your nas. Does the router have an ftp server? Is the port closed when you disconnect the nas.
  • ENDLESS
    Could you provide the screenshot of how you configure FTP port on NAS and port forwarding on router? As I know, port 23 is for telnet and I'm not sure if there is any problem to configure like that.
  • William990
    Sorry i mean Port 21. I'll post the screenshot of router and NAS. Thanks.
