Locked out of VMG3925
Trixxz
I have the VMG3925-B10C. It was on firmware V5.13(AAVF.12)C0. The 5GHz wi-fi had been cutting out once every couple of days or so. I had seen around here that the B10B has possibly had this fixed in a newer firmware and I gathered they use the same firmware anyway so I thought I'd try that
It got stuck in the self-test for ages with the power LED blinking green. After at least 10 minutes, I gave up waiting and used the factory reset button.I can access web UI, SSH, telnet, and FTP interfaces but the "default" login doesn't work at all! I've tried all sorts but I'm completely locked out. This includes:
- My original login
- admin/1234 (which is printed on the back)
- admin/admin
- admin/password
- admin/<blank> (web UI doesn't allow it at all, others reject it)
#SP_May_2020
Hi @TrixxzIn order to provide you a better support, please check your mailbox and provide the requested information. Thanks.
Can anyone else on the zyxel team help? I need to get this router back up and running for our home security system to connect to the internet0
- 234 Nebula Ideas
- 6.7K Security
- 704 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 114 Security Highlight
