Multy Plus: allowing employee access to NAS
jorima
jorima Posts: 2 image  Freshman Member
edited June 2020 in Personal Cloud Storage
Hi!
I've recently purchased a Multy Plus and created two wifi-networks, one admin and one for employees. I have an external NAS connected via ethernet to the router, and can access it through the admin wifi, however when connecting through the employee wifi the NAS can't be found. How can I setup so that the device(s) connected via cable also are accessible in the employee wifi?
Thanks! /Johan
#Multy_June_2020
  • Zyxel_Eric
    Zyxel_Eric Posts: 279 image  Zyxel Employee
    First Answer First Comment
    Dear Sir,
    Port connection on Multy is only for Main Network connection.
    That's why the NAS cannot be accessed from Guest Network.
    I have moved this post to Ideas Discussions.
    Best Regards,
    Eric
  • Zyxel_Eric
    Dear Sir,
    Best Regards,
    Eric
  • jorima
    Ok, thanks for the quick feedback! Would be a good function, to avoid having everyone on the admin network. Regards /Johan
