Zyxel Drive stopped connecting to my NAS
Csongor
Hi All,
I am not sure what I have changed, if I have done any, but the Zyxel Drive app stopped connecting to my NAS520 at all.
My NAS is on my latest version V5.21(AASZ.4), I restarted it, I made sure that the uPnP enabled on my router, I have removed the NAS from my myZyxelCloud account, and I am not able to add it back. I add the MAC and the SN, it tells me to press the button and when I do, the website says Device not found.
I have no idea what got broken. I hope this is now another case of factory reset the device. All my issues I had with Zyxel was support telling me to factory reset this damn device and start over.
Csongor
Csongor
#NAS_June_2020
Have you checked the status In Control Panel > UPnP Port Mapping > UPnP Router?
Also, check gateway and DNS IP address to make sure NAS can reach the internet.0 -
Yes, in the UPnP page it says that a UPnP capable router in found. And the network access is OK as well, as in the firmware upgrade page I am getting a message that the firmware is up-to-date, so it is able to check latest firmware version.0
Maybe you can try to re-install the myZyXELcloud-Agent app on NAS and make sure its version is 1.0.6 (latest). Then, delete the NAS that originally paired on myZyxelcloud and make sure PC and NAS is in the same LAN and pair them again. After finishing all steps, try again if the Zyxel Drive is able to connect to NAS.
I have a similar problem, my NAS 542 is suddenly unable to connect via WebDAV or HTTP/HTTPS web interface. I can connect locally though. I have restarted the NAS and router multiple times. It seems that the NAS stopped communicating with the zyxel servers - if I log in to mycloud.zyxel.me, the IP address listed for my NAS is different then my current IP - is there a way to manually sync the NAS with zyxel servers in order to get a correct IP for the DNS I have adopted ([nasname].zyxel.me)?
(UPnP and router Port Forwarding rules are set correctly)0 -
Okay, I had to reinstall the Zyxel cloud, re-pair the NAS to my email account, and set the DDNS again.
OK, I have done the same thing but it did not help.
1) I have re-installed the cloud agent app
2) uPnP is enabled on the router the device finds the uPnP device and I can see the external IP as well. I have NOT configured any port mappings
3) I have added the settings in DyDNS as well, and it is active
Still the pairing does not complete, I try to add my device manually, but as soon as I press the button on the NAS the website says "Device not found".0 -
so you have already tried to factory reset but still doesn't work?0
Hi...i think there is connection to NAS via http protocol as default port 80, and seems you have paired your NAS326 to Zyxel, but the http port would be changed by cloud if the port is the same as router's, so you have to check the UPnP setting in zyxel and enable http feature and see the port number.
quick turn pcb assembly in usa
- 238 Nebula Ideas
- 6.8K Security
- 747 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
