Entware-ng Install on NSA210
nikolop_ang
@Mijzelf is there a chance to install entware-ng to nsa210? When trying the package from MetaRepository i am getting this error.
#NAS_Jan_2020
Flushing memory buffer
Starting up
Flushing done
[23:03:13] FATAL: /opt is a directory
#NAS_Jan_2020
I don't know. Theoretically yes, but I don't have a 210 to test it.The directory /opt shouldn't be there, and AFAIK it isn't in the initramfs. Maybe it's added by some package? Do you have shell access? What doesls -l /give?0
Hi,same problem here but on a 326. I'm trying to install Entware (to get transmission updated) but /opt directory already exists and contains two folders,/sdk/arm-marvell-linux-gnueabihf and /var.folder's permissions aredrwxr-xr-x 4 root root 0 Jun 13 13:07 optCan you help me?Thanks.
Does it have an diverging timestamp?ls -l /0
hi, thanks fo the quick reply:are tou asking for this?drwxr-xr-x 3 root root 0 Jun 12 13:46 sdk
drwxrwxrwx 3 root root 0 Jun 13 13:07 varYesterday I reinstalled metarepository to fix a package display issue (download list fail error) and myzyxelcould and tweaks pkg got finally updated, but I tried to install entware only this morning, so it seems it created the var dir, which contains a log dire and Entware-ng.log file:Reopened logfile at Sat Jun 13 13:13:17 CEST 2020
[13:13:17] Execute /opt/etc/init.d/rc.unslung stop
[13:13:17] /i-data/8065a584/.PKG/Entware-ng/etc/init.d/Entware-ng: line 596: /opt/etc/init.d/rc.unslung: not found
[13:13:17] Done /opt/etc/init.d/rc.unslung stop
Closed logfile at Sat Jun 13 13:13:17 CEST 2020
Reopened logfile at Sat Jun 13 13:23:45 CEST 2020
[13:23:45] Execute /opt/etc/init.d/rc.unslung stop
[13:23:45] /i-data/8065a584/.PKG/Entware-ng/etc/init.d/Entware-ng: line 596: /opt/etc/init.d/rc.unslung: not found
[13:23:45] Done /opt/etc/init.d/rc.unslung stop
Closed logfile at Sat Jun 13 13:23:45 CEST 2020
are tou asking for this?No, I meant the timestamps in the root. The rootdirectory is in ram, the initramfs, and the directories in it have a fixed timestamp on boot. If the /opt directory is newer than others, it's created after boot, probably by some package. In that case you could simply delete or rename it, and re-enable the Entware package. The package will probably be started after Entware on boot (for most packages it's alphabetical), and so it will share the Entware directory, where /opt symlinks to.
you mean thisdrwxr-xr-x 2 1013 1000 0 Jun 12 13:29 bin
drwxr-xr-x 5 root root 0 Jun 12 13:29 dev
drwxr-xr-x 2 1013 1000 0 Mar 18 00:03 e-data
drwxr-xr-x 21 1013 1000 0 Jun 13 12:29 etc
drwxr-xr-x 5 1013 1000 0 Jun 12 13:28 firmware
drwxr-xr-x 7 1013 1000 0 Jun 12 13:46 home
drwxrwxrwx 4 root root 0 Mar 6 2018 i-data
-rwxr-xr-x 1 1013 1000 5072 Mar 17 23:54 init
drwxr-xr-x 6 1013 1000 0 Jun 12 13:29 lib
lrwxrwxrwx 1 root root 11 Mar 18 00:03 linuxrc -> bin/busybox
drwxr-xr-x 3 1013 1000 0 Jun 12 13:28 mnt
dr-xr-xr-x 151 root root 0 Jan 1 1970 proc
drwxr-xr-x 9 root root 1024 Mar 18 00:05 ram_bin
drwxr-xr-x 2 1013 1000 0 Mar 18 00:03 root
drwxr-xr-x 2 1013 1000 0 Jun 12 13:29 sbin
dr-xr-xr-x 12 root root 0 Jun 12 13:28 sys
drwxrwxrwx 11 1013 1000 0 Jun 13 13:18 tmp
drwxr-xr-x 8 1013 1000 1024 Mar 17 23:54 usr
drwxr-xr-x 14 1013 1000 0 Jun 12 13:29 varIs seems effectively newer then others... can I safely delete it? I just do not understand why the timestamp of the sdk directory in the opt folder is one day older and it contanis /opt/sdk/arm-marvell-linux-gnueabihf/build/imagemagick-6.9.0-4 and then 4 more emplty directories: coders filters magick wand. What is imagemagick? Nothing I willed to install.thanks
Ah, I read elsewhere in this forum that could be part of myzyxelcloud, which I updated yesterday... I need the zyxelcloud service, can I safely delete this imagemagick folder?
You can safely delete it. Imagemagick is a package for image manipulation, and can be used to create thumbnails. Maybe it is installed with Zyxelcloud.
Thanks, I deleted the opt folder and I got Entware installed, I even installed the updated transmission, but something doesn't work propely, probably it's going in conflict with the zypkg one... Any advise is more then welcome, but maybe for another thread...Anyway, thanks a lot for the help.0
You should at least uninstall the zypkg one.
- 588 USG FLEX H Series
- 477 News and Release
