Multy X logs
So if I understand correctly, SSH login is only provided as a backdoor for remote control by Zyxel staff and there is no logging visible to the user? There isn't even a web interface (well, technically there is: entering Multy's IP-address redirects to /gui and shows 404 Not Found) so if the app stops working, which it does sometimes for unknown reasons, I have no control over the network.
Why Zyxel is treating their customers like they are complete idiots and hide behind GDPR instead of offering a local log dump is beyond me. Every other wifi system I have been using (from Netgear, Linksys and AVM) have useful logging and offer some level of control to their users. I was experiencing network problems today and the logs in the app were not giving information at all. I only could solve the problem by rebooting the Multy's in a certain order, I have no clue what went wrong or what caused it and I have no idea if it will happen again. The wifi network is working now, but I don't feel confident it will keep working and I am not going to buy another Zyxel product offering this low level of control...1 -
Dear Sir,
The Multy X is targeted for the basic users, that's why it only supports App management.
If you prefer Web management, Multy Plus should be a better choice for you.
https://www.zyxel.com/products_services/AC3000-Tri-Band-WiFi-System-Multy-Plus/
Regarding your issue,
May I know what kind of Network problem on your Multy devices?
Were you able to access Multy App when the issue happened?
If you need any assistance, please "send Feedback" from your Multy App, and we can assist you after we analyze the log.
Best Regards,
Eric0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
