What's the max. speed between Multy X and Multy mini?
Luigi Chang
Luigi Chang Posts: 3 image  Freshman Member
edited June 2020 in Multy WiFi System
What is the maximum transmission speed between the Multy X and the Multy Mini if the Internet is set to turn off the "Daisy Chain"?
#Multy_Jun_2020
  • Zyxel_Eric
    Zyxel_Eric Posts: 279 image  Zyxel Employee
    First Answer First Comment
    Dear Sir,
    Base on the spec, Multy mini has 1300Mbps wireless transfer rate on 5G.
    The wireless backhaul connection is on 5G wifi.
    So the max transfer speed for Multy Mini to Multy X is 1500Mbps
    Please Note, this rate is a theoretical value.
    The actual data transfer rates may vary from network conditions including: distance, network traffics, building site material/construction, interference from other wireless devices and other adverse factors.
    Regarding the Daisy Chain,
    Daisy Chain setting will not affect the speed rate between Multy.
    Best Regards,
    Eric
  • Luigi Chang
    Still has few questions.
    XDSL <=======> Multy X <======> Multy mini
                 by cable                   by cable
    Above is my Multy’s connection.
    1. My XDSL is 500Mbps/300Mbps.
    2. XDSL, Multy X and Multy mini are connected by cable.
    3. Multy X: DL 485Mbps, UL: 325Mbps from the internet
    4. Multy X to Multy mini is 850Mbps and 875Mbps
    3 and 4 are tested by Multy App.
    My question is why is the speed from Internet to my Multy Mini only DL 130Mbps and UL 90Mbps?
    Thanks.
  • Zyxel_Eric
    Dear Sir,
    1. Is the 130/90 the result from the Diagnose page of Multy App?
    Or the result that you test from your PC which connects to the Multy Mini via Wifi?
    2. Can you provide the Diagnose result page from App?
    Best regards,
    Eric
  • Luigi Chang
    Hi Eric,
    This result is from App. (By diagnose)
    If you can provide me with your mail address. I can send you the screenshot for reference.
    Thanks.
    Luigi
  • Zyxel_Eric
    Dear Sir,
    I have contacted you via private message, please check your message box for further assistance.
    Best Regards,
    Eric
  • Newbi
    Newbi Posts: 4 image  Freshman Member
    Hi Eric, Can you share the result of your finding or resolution on the forum? I have a similar query.
