Multi Plus (WSQ60) standard mode
smi73
Hello
I have Zyxel Multi (WSQ60) plus setup used together with a fiber based internet connection.
My ISP is stating that I can connect the WSQ60 to the fiber mediaconverter/fiber termination (Tilgin MSA974) directly via an ethernet cable and run the wsq60 in standard mode (router mode). That makes sense since I am doing that on another location with another brand of router.
When I try to do that I am able to get an internet connection from the WSQ60 but only for a limited time. I can see in the log that there is a lot of disconnects.
Putting the ISP provided router between the mediaconverter/fiber termination and the WSQ60 and switching the WSQ60 to run in bridge mode, the connection is stable.
I don't want to use ISP provided router as a "middle man" but would like to connect the WSQ60 directly to the fiber media-converter (Tilgin MSA974). I assume that it is some kind of interoperability issue between the Zyxel and Tilgin device. I also assume that it is a normal usecase.
Any suggestion on how to proceed (besides running in bridge mode together with the ISP router) ?
Thanks in advance.
Best regards
#Multy_May_2020
Thanks in advance.
Best regards
#Multy_May_2020
Dear Sir,
1. Can you provide the topology of your Multy Plus?
Please don't connect your Multy as below Topology in NAT Mode.
Modem--------Root Multy
|------------Extender Multy
Please refer to the link for Ethernet backhaul:
https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=017839&lang=EN
2. Please provide the log that appear in your Multy App.
Best Regards,
Eric0 -
Hello
Thanks for the feedback.
I have attached a drawing on how i did connect the different devices.
I have also attached the log.
Thanks in advance.
Best regards
Dear Sir,
Thanks for the file.
I have contacted you via Private Message box, please check your message box for further assistance.
Best Regards,
Eric0 -
Thank you very much for your hard work.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
