Does Multy X AC3000 support Ethernet Backhaul?
shayanitalia
shayanitalia Posts: 10  Freshman Member
edited June 2020 in Multy WiFi System
I want to know if Ethernet Backhaul Setup is supported on the Multy X AC3000 system and what the maximum Wifi Speed is on the 5 GHz channel across a 1gbps Internet connection. So basically if I connect a CAT 7 cable from my main Multy X Model (GIGA LAN OUTPUT) to my Multy X WAN port, will the ethernet backhaul system work by giving a much more rock solid connection.
#Multy_June_2020
  • Zyxel_Eric
    Zyxel_Eric Posts: 279  Zyxel Employee
    First Answer First Comment
    edited June 2020
    Dear Sir,
    Multy X has a dedicated band for backhaul connection, and the maximum rate is 1733Mbps.
    However, 1733Mbps is a theory rate, Actual data transfer rates may vary from network conditions including: distance, network traffics, building site material/construction, interference from other wireless devices and other adverse factors.
    Multy X Support Ethernet backhaul connection, please refer to the link.
    https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=017839&lang=EN
    The Ethernet backhaul will provide much stable connection for your Extender Multy.
    Best Regards,
    Eric
  • shayanitalia
    edited June 2020
    This doesn’t answer my question:
    1. does Multy super Ethernet backhaul?
    2. What is the fastest Wi-Fi speed one can get (not wireless backhaul) on the 5Ghz channel across a 1gbps connection!
    Please READ before you answer.
    thanks
  • Mijzelf
    Mijzelf Posts: 2,923  Guru Member
    Maybe you should read the answer? I see the answer on both questions.
  • odifoke
    odifoke Posts: 29  Freshman Member
    1. Yes
    2. 866Mbps
