NFS server broken (possible RPC issue)
t23
Using the ABAG.5 firmware on a NAS542, i installed
NFS 1.3.0zypkg007 and added a share. This could not be mounted - macOS
gave the error "This file server will not allow any additional users to
log on", both when using v4 and v3.
So, i ssh'ed into the box, and found the problem is much stranger:
clnt_create: RPC: Port mapper failure - Unable to receive: errno 111 (Connection refused)
admin@542:/i-data/xxxxxxxx/.PKG/NFS/bin$ ./rpcinfo -p
No remote programs registered.
admin@542:~$ netstat -an | grep 2049
tcp 0 0 0.0.0.0:2049 0.0.0.0:* LISTEN
udp 0 0 0.0.0.0:2049 0.0.0.0:*
But lsof (run as root) cannot tell me what process is actually attached to port 2049 (could imagine it's a kernel module then).
rpcbind, rpc.mountd and rpc.statd are all running.
Anybody have any idea what is going on and how to fix it? Thanks in advance!
#NAS_June_2020
I googled "This file server will not allow any additional users to log on" on the Internet and found this: https://discussions.apple.com/thread/4227674?page=1 Hope it can help.0
I have ran the same rpcinfo -p on a nfs server I have and got the following.When running it on the nfs server:$ rpcinfo -p
program vers proto port service
100000 4 tcp 111 portmapper
100000 3 tcp 111 portmapper
100000 2 tcp 111 portmapper
100000 4 udp 111 portmapper
100000 3 udp 111 portmapper
100000 2 udp 111 portmapper
100005 1 udp 20048 mountd
100005 1 tcp 20048 mountd
100024 1 udp 58497 status
100024 1 tcp 53218 status
100005 2 udp 20048 mountd
100005 2 tcp 20048 mountd
100005 3 udp 20048 mountd
100005 3 tcp 20048 mountd
100003 3 tcp 2049 nfs
100003 4 tcp 2049 nfs
100227 3 tcp 2049 nfs_acl
100003 3 udp 2049 nfs
100003 4 udp 2049 nfs
100227 3 udp 2049 nfs_acl
100021 1 udp 57844 nlockmgr
100021 3 udp 57844 nlockmgr
100021 4 udp 57844 nlockmgr
100021 1 tcp 37180 nlockmgr
100021 3 tcp 37180 nlockmgr
100021 4 tcp 37180 nlockmgrRunning the same command against the nfs server host from other host:rpcinfo -p nfs_server_ip_address
100021 4 tcp 37180 nlockmgrProbably as long as you don't see the same there might be services not running, like rpcbind....All this just in case you didn't figure it out by yourself.
It gets more hairy. After a reboot, nfs works - until you disable and reenable it from the control panel, then it reverts to the originally described behaviour.Restarting as root on the NAS itself makes no difference.Any other ideas?
Thanks so far, btw!0 -
Hi t23,Facts:- Reboot - the nfs service is running.- Changind the state of the nfs service via web interface practically disables it and it reamins so regardless of further actions.I think that looking through all avaiable logs would help, given the fact you can login to it via ssh and elevate to root your rights.Identify how the service(s) are started - for example, as root, run:a. systemctl list-unit-filesorb. service nfsd statusIf a. then continue withsystemctl list-unit-files | grep nfsMake note of the output and use it in the following commandsystemctl status service_from_above -lThis will show you the status of the service.systemctl stop service_from_aboveto stop servicesystemctl start service_from_aboveto start service
More infoThe goal, I understand, is to identify the correct command to start/stop the nfs service.Otherwise, if you only want the service to run, just reboot and not act upon it from the web interface.
The NAS doesn't run systemd, so systemctl doesn't work/exist on a 542. To stop/start a package, you'll have to execute/i-data/sysvol/.PKG/<packagename>/etc/init.d/<packagename> [startup|shutdown]The package name in this case is NFS. so the start command is/i-data/sysvol/.PKG/NFS/etc/init.d/NFS startupThere is no status command.
Correct, the NAS542 uses init scripts. Stopping and starting from the nfs package's script gives the same results as disabling and reenabling from the web interface (most likely uses the same script), i.e. that all portmapper services are completely frozen and/or simply not there.just reboot and not act upon it from the web interfaceRight - not really a solution, but best workaround for sure.
Is it possible that there are connections on NFS when you restart it, causing the daemons to 'stick'?
Is it possible that there are connections on NFS when you restart it, causing the daemons to 'stick'?Nopes - i get your way of thinking, but that is not the case.
- 441 Beta Program
- 293 Service & License
