Can I control or how do I tell which node I am connected to (Multy X and/or Multy Mini)
T_ZyxelUK
How can I find out which Multy X node I am connected to on my network or if I am connected to my Multy Mini.
If you can check this, can I force a device to join a specific device upon arrival?
T
#Multy_Jul_2020
T
#Multy_Jul_2020
Multy support Roaming feature, which can help your device to select a better connection with nodes.
Please refer to the link for detail information :
https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=016610&lang=EN
Devices will select the connection itself, and that is the behavior of the wireless device, Multy cannot force the connection on them.
thanks for the response Eric.for the second part of the question, ifs there a way i can check which Multy i am connected to though?Thanks,T0
Dear Sir,
You can download WiFi analyzer on your Andriod phone, it can provide the BSSID of the wifi that you connected, and you can base on the BSSID to check which Multy you connected.
https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer&hl
Best Regards,
Eric0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
