Zyxel8825-T50 extremely slow USB network
Sydney
Posts: 8 Freshman Member
Ever since I have the Zyxel8825-T50 my internet itself runs smoothly on 100Mb/s. No wonder since I own one of the fastest configuration at this moment available. No worries there.
I have this modem because of its possibilities to run an USB hard drive or flash drive to have my own home network. It arrived two months ago, so it should be loaded with the latest firmware, I guess.
What a disappointment that I can't get beyond 500 Kb/sec (yes, Kb) file transfer, not to mention that it even halts after a few seconds.
So obviously playing music (let alone a video) from my USB isn't working. It stutters all the time.
Every tip I could possibly find on the internet cannot solve this issue.
So what is wrong with this Zyxel modem?
Hi Hummel,The Firmware-version is V5.50(ABPY.1)b11.I'm not sure what kind of test results you mean. But hopefully this will clarify.
I have included a screenshot of such a typical "file transfer" from the network plugged in USB drive at 192.168.1.14\usb1_sda1 to my Intel i9 9700KF desktop. My other desktop (an i7) has the same. So also here no slow computer, that may cause any issues.It's a 6Mb mp3 and you can see the speed is dramatically low.What I forgot to mention is that also my 4K Chromecast (Android phone to TV) has similar issues. While on the phone the stream is flawlessly, the Chromecast occasionally "stutters." I'm quite sure this is related to the same problem.
I run both my desktops through a Cat6 cable, not even Wifi. Obviously I use Wifi for my phone.
I live in the Netherlands.I hope you can "tackle" this problem.Best wishes,Sydney
Is there a difference between the VMG8825-T50 and VMG8825-T50K e.g. in terms of firmware.My VMG8825-T50 seems to have - according to the 192.168.1.1 data - a very different firmware than the "K" version.Could it be possible, that my VMG8825-T50 has been loaded with the wrong firmware?
Thanks for the info, Hummel.I mentioned this firmware controversy to customer service of T-Mobile; someone will come and check in another week. Hopefully it will be sorted out.0
Yes, Hummel. Even a brand new 128Gb 3.0 didn't do the trick.
Also my Chromecast doesn't stream as smoothly as my phone.But you have mentioned already "customized firmware" with T-Mobile. So maybe there is something wrong.On the other hand, am I the only one with this complaint?...
SOLVED it myself eventually. For some reason the WPS button on the back has to be activated by keeping it pressed for over a second.It didn't tell in the installation process.Now I can copy around 8Mb/s.0
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
