NAS540 data lost on harddisk after factory reset
2»
  • PawelS
    PawelS Posts: 8 image  Freshman Member
    1. I didnt Mount them as I don't know why. I will try later.
    2. Power loss did that.
  • PawelS
    Should I use command exactly as you posted?
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    There are variations possible, but this should work.
  • PawelS
    i did it.
    last out put is:
    md3: detected capacity change from 0 to 995973988352
     md2: unknown partition table
     md3: unknown partition table
    bio: create slab <bio-2> at 2
    EXT4-fs (dm-3): ext4_check_descriptors: Checksum for group 128 failed (62833!=0)
    EXT4-fs (dm-3): group descriptors corrupted!
    Rounding down aligned max_sectors from 4294967295 to 4294967288
    EXT4-fs (dm-1): warning: mounting fs with errors, running e2fsck is recommended
    EXT4-fs (dm-1): recovery complete
    EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
  • PawelS
    And still did not get my folders.
  • PawelS
    how should i mount second disk?
  • Mijzelf
    You should be able to see (part of) your folders in /tmp/mountpoint:
    ls -l /tmp/mountpoint/
    Basically the same. But you need to use a different mountpoint
    mkdir /tmp/mountpoint2
    mount /dev/dm-3 /tmp/mountpoint2
    dmesg | tail
    But I don't know if it will happen. Something is wrong with dm-3, and I don't know what that means:
