Checking HDD SMART data with a NAS326?
Tobias Claren
Tobias Claren Posts: 6 image  Freshman Member
Second Anniversary
edited March 2020 in Personal Cloud Storage
Hello.
Is it possible to check and observe the SMART informations of the harddiscs (bad sectors etc.) in a NAS326? Perhaps with a log. To show and save every change (new bad sector etc.).
If the counter is rising, i will call the seller of the used HDD.
And is there a automatic alarm, if a HDD in a RAID 1 does not work?
Without alarm, i can not change the defective hdd. And when the second HDD is defect, all data are lost.
#NAS_Mar_2020
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    The 'normal' smartctl tool is available. To see the smart values execute (as root)
    smartctl -a /dev/sda
    smartctl -a /dev/sdb
    If you want to monitor some specific value, you'll have to write a script for that.
    AFAIK the NAS has an automatic alarm when the array get degraded, and maybe also when SMART tells the disk is in danger. But I haven't experienced them.
  • Kobtul
    Kobtul Posts: 1 image  Freshman Member
    I have a trouble on the NSA 325v2 with these commands. I have bought 2 6tb seagate ironwolf pro drives, but running smartctl -a /dev/sda gives:
    smartctl 6.6 2017-11-05 r4594 [armv5tel-linux-2.6.31.8] (localbuild)
    Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
    === START OF INFORMATION SECTION ===
    Vendor:               Seagate
    Product:              ST6000NE0021-2EN
    Revision:             EN02
    User Capacity:        6,001,175,126,016 bytes [6.00 TB]
    Logical block size:   512 bytes
    Device type:          disk
    Local Time is:        Sat Jul 18 01:05:27 2020 CEST
    SMART support is:     Unavailable - device lacks SMART capability.
    === START OF READ SMART DATA SECTION ===
    Current Drive Temperature:     0 C
    Drive Trip Temperature:        0 C
    Error Counter logging not supported
    Device does not support Self Test logging
    which is weird. I tried both entware and stock smartctl. Are these drives too new for the NAS to be able to read SMART values?
  • Mijzelf
    On a 325 (and other Kirkwood devices) the sata chip has to be specified.
    smartctl -d marvell -a /dev/sda
