I have Ethernet backhaul. Can’t I use the fast tri band for wifi now? Like new routers do?
shayanitalia
I have Ethernet backhaul. Can’t I use the fast tri band for wifi now? Like new routers do? The wireless backhaul band of 1733mbps???? New routers allow you to use this band called 5Ghz 2. Multy should allow one to do this if using Ethernet backhaul is used.
#Multy_Jul_2020
#Multy_Jul_2020
3
this is a good idea, if it can understand that you are already using ethernet backhaul.
This is a great idea! A free performance upgrade is always good to have
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
