NAS540 data lost on harddisk after factory reset
1. I didnt Mount them as I don't know why. I will try later.
2. Power loss did that.0 -
Should I use command exactly as you posted?0
There are variations possible, but this should work.
i did it.
last out put is:md3: detected capacity change from 0 to 995973988352md2: unknown partition tablemd3: unknown partition tablebio: create slab <bio-2> at 2EXT4-fs (dm-3): ext4_check_descriptors: Checksum for group 128 failed (62833!=0)EXT4-fs (dm-3): group descriptors corrupted!Rounding down aligned max_sectors from 4294967295 to 4294967288EXT4-fs (dm-1): warning: mounting fs with errors, running e2fsck is recommendedEXT4-fs (dm-1): recovery completeEXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)~ #0 -
And still did not get my folders.
how should i mount second disk?
You should be able to see (part of) your folders in /tmp/mountpoint:
ls -l /tmp/mountpoint/
how should i mount second disk?Basically the same. But you need to use a different mountpointmkdir /tmp/mountpoint2mount /dev/dm-3 /tmp/mountpoint2dmesg | tailBut I don't know if it will happen. Something is wrong with dm-3, and I don't know what that means:EXT4-fs (dm-3): ext4_check_descriptors: Checksum for group 128 failed (62833!=0)
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
