Zyxel PLA5456 powerline ethernet kit question
bomishketi4
Hi @bomishketi4 ,
It's not available for PLA5456 to do firmware upgrade, so you can use it directly.
May I know if there's any problem for using the PLA5456?
Thanks.0 -
Eu comprei um powerline 5456 e não consigo faze-los funcionar0
Hi @Tatiana ,
Here is the user guide of the PLA5456 for your reference.
https://download.zyxel.com/PLA5456/user_guide/PLA5456_v7.0.2_Ed6.pdf
You may check chapter 2 for how to pair the PLA 5456 and detail LED status information.
If you can't set up successfully, please share us the detail issue symptom and topology, and then we'll help to check.
Thanks.0
- 588 USG FLEX H Series
- 477 News and Release
