auto reboot LTE3301-PLUS
JanneS
JanneS Posts: 1 image  Freshman Member
edited January 2024 in Mobile Broadband
Hi, is it possible define scheduled autoreboot LTE3301 model or just for brandband interface ?
#SP_Feb_2020
  • bbb
    bbb Posts: 35
    Sixth Anniversary
    Hi JanneS,
    Neither option is available on the GUI.
    Is there any problem with your LTE3301-PLUS?
    Regards,
    Bob
  • Runner73
    Runner73 Posts: 17
    Hi
    I'm really interested to define a scheduled reboot too. My LTE PLUS lost wan connection after a couple of hours and the only way to reconnect is reboot the router. I already asked for a hardware substitution so I can exclude hardware problem. Seems a firmware problem but there isn't any firmware update
  • RoNiN
    RoNiN Posts: 1
    edited November 2023
    I'd also like to note the necessity of such a feature. Especially on rural remote locations, band availability have problems. I left my modem on forced 4G mode with some specific bands to use (LTE_BC1, LTE_BC41), however, I lost connection after 30 days, when I came back after 3 months, I found my modem stuck at WCDMA900 mode. Only a reboot solved the problem. TP-LINK modems have such a feature. In case of losing remote connection, this feature would at least give a time window to have your work done. It is important for remote surveillance.
