VMG8825-T50 USB shows 2097151 MB capacity
Lemodile
I'm having some trouble setting up USB file sharing properly.. I have an external 4TB hard drive, which supports usb 3.0. In windows this partition shows up as follows:
In the Zyxel control panel however, the capacity is limited to 2097151 MB! Some searching tells me this is a common problem but none of the causes listed online seem to match my situation.
I've ruled out:
- MBR - The disk I want to use shows up as GPT on disk management
- Partition size limits - In windows it works fine as shown above
Has anyone run into similar problems? Any tips? I'd greatly appreciate it.
Thanks in advance and kind regards from the Netherlands.
- 588 USG FLEX H Series
- 477 News and Release
