Got a problem with NAS 542 raid 5 volume down
  • Axberg
    Axberg Posts: 14 image  Freshman Member
    Hi
    Maybe I'm just to stupid to understand, wh.en I make the directory and then mount, then I make a reboot and I got the same 2 failure as before
    ~ # mkdir /mnt/mountpoint
    ~ #  mount /dev/vg_c1b2735e/lv_168e8bf4 /mnt/mountpoint
  • Axberg
    Tried this after reboot:
    mount: mount point /mnt/mountpoint does not exist
    ~ # e2fsck /dev/vg_c1b2735e/lv_168e8bf4
    e2fsck 1.42.12 (29-Aug-2014)
    /dev/vg_c1b2735e/lv_168e8bf4 is mounted.
    e2fsck: Cannot continue, aborting.
  • Mijzelf
    Mijzelf Posts: 3,022 image  Guru Member
    So it's already mounted. That is not surprising, as that is the default situation. The only reason that is was not mounted, was because of the error, which you repaired.
    Have you already checked if your shares are back?
    If not, you can find the current mountpoint using
    cat /proc/mounts
    and look into the filesystem using
    ls -l <mountpoint>
    where you have to substitute the 'real'  mountpoint.
  • Axberg
    ~ # cat /proc/mounts
    rootfs / rootfs rw 0 0
    /proc /proc proc rw,relatime 0 0
    /sys /sys sysfs rw,relatime 0 0
    none /proc/bus/usb usbfs rw,relatime 0 0
    devpts /dev/pts devpts rw,relatime,mode=600 0 0
    ubi7:ubi_rootfs2 /firmware/mnt/nand ubifs ro,relatime 0 0
    /dev/md0 /firmware/mnt/sysdisk ext4 ro,relatime,user_xattr,barrier=1,data=ordered 0 0
    /dev/loop0 /ram_bin ext2 ro,relatime,user_xattr,barrier=1 0 0
    /dev/loop0 /usr ext2 ro,relatime,user_xattr,barrier=1 0 0
    /dev/loop0 /lib/security ext2 ro,relatime,user_xattr,barrier=1 0 0
    /dev/loop0 /lib/modules ext2 ro,relatime,user_xattr,barrier=1 0 0
    /dev/loop0 /lib/locale ext2 ro,relatime,user_xattr,barrier=1 0 0
    /dev/ram0 /tmp/tmpfs tmpfs rw,relatime,size=5120k 0 0
    /dev/ram0 /usr/local/etc tmpfs rw,relatime,size=5120k 0 0
    ubi3:ubi_config /etc/zyxel ubifs rw,relatime 0 0
    /dev/mapper/vg_c1b2735e-lv_168e8bf4 /i-data/168e8bf4 ext4 rw,noatime,user_xattr,barrier=1,stripe=48,data=ordered,usrquota 0 0
    configfs /sys/kernel/config configfs rw,relatime 0 0
    ~ # ls -l <mountpoint>
    sh: syntax error: unexpected newline
  • Axberg
    Hi
    Here are the new
    ~ # cat /proc/mdstat
    Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
    md2 : active raid5 sdb3[1] sdc3[4] sdd3[3]
          11708660736 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [_UUU]
    md1 : active raid1 sdc2[4] sdd2[5] sdb2[1]
          1998784 blocks super 1.2 [4/3] [_UUU]
    md0 : active raid1 sdb1[6] sdd1[5] sdc1[4]
          1997760 blocks super 1.2 [4/3] [U_UU]
    unused devices: <none>
    ~ # mdadm --examine /dev/sd[abcd]3
    mdadm: cannot open /dev/sda3: No such device or address
    /dev/sdb3:
              Magic : a92b4efc
            Version : 1.2
        Feature Map : 0x0
         Array UUID : c1b2735e:9b10b90c:cb9b6690:e84965d6
               Name : NAS542:2  (local to host NAS542)
      Creation Time : Mon Feb 19 16:18:55 2018
         Raid Level : raid5
       Raid Devices : 4
     Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)
         Array Size : 11708660736 (11166.25 GiB 11989.67 GB)
        Data Offset : 262144 sectors
       Super Offset : 8 sectors
              State : clean
        Device UUID : ad1bbcba:851fe7ce:9b4e0515:15f8029b
        Update Time : Mon Aug  3 18:44:22 2020
           Checksum : ec118de4 - correct
             Events : 20785
             Layout : left-symmetric
         Chunk Size : 64K
       Device Role : Active device 1
       Array State : .AAA ('A' == active, '.' == missing)
    /dev/sdc3:
              Magic : a92b4efc
            Version : 1.2
        Feature Map : 0x0
         Raid Level : raid5
       Raid Devices : 4
              State : clean
        Device UUID : 0182f1cb:4bcb13a7:0ccde221:ae77558d
           Checksum : d4a39e0b - correct
             Events : 20785
         Chunk Size : 64K
       Device Role : Active device 3
    /dev/sdd3:
              Magic : a92b4efc
            Version : 1.2
        Feature Map : 0x0
         Raid Level : raid5
       Raid Devices : 4
              State : clean
        Device UUID : 6834c489:800c6cb4:67c317fc:4e3d686f
           Checksum : 5c164e22 - correct
             Events : 20785
         Chunk Size : 64K
       Device Role : Active device 2
    I am very grateful for your attempt to help me
  • Mijzelf
    The filesystem is mounted on /i-data/168e8bf4, so the view command should be
    ls -l /i-data/168e8bf4
  • Axberg
    Hi again
    Got this, but still have disk group down and raid degraded.
    ~ # ls -l /i-data/168e8bf4
    drwxrwxrwx    4 root     root          4096 Feb 20  2018 admin
    -rw-------    1 root     root          9216 Feb 19  2018 aquota.user
    drwx------    2 root     root         16384 Feb 19  2018 lost+found
    drwxrwxrwx    2 root     root          4096 Apr 17 04:38 music
    drwxrwxrwx    2 root     root          4096 Jan 12  2020 photo
    drwxrwxrwx  510 root     root         20480 May  7 16:30 video
    How to go from here?
    I still got one harddrive that is not in the raid5 , I got a raid 5 with 4 drives to begin with, before the crash
  • Mijzelf
    The array is degraded, yes. To solve that you'll have to use the 'repair' button in the webinterface. But
    ~ # cat /proc/partitions
    major minor  #blocks  name
    <snip>
       8        0 3907018584 sda
       8       16 3907018584 sdb
       8       17    1998848 sdb1
       8       18    1999872 sdb2
       8       19 3903017984 sdb3
       8       48 3907018584 sdd
       8       49    1998848 sdd1
       8       50    1999872 sdd2
       8       51 3903017984 sdd3
       8       32 3907018584 sdc
       8       33    1998848 sdc1
       8       34    1999872 sdc2
       8       35 3903017984 sdc3
    your sda disk has lost it's partition table. So first check the SMART status of that disk. It might be damaged.
    What do you mean by that?
  • Axberg
    Hi
    The harddisk is a brand new one, I've got one with a klonk noise and then the nas crashed.
    There is no option to repair the array, when a restart the nas it's bepping and then I open the web interface I got a warning that the disk group is down and then a few second after I got the raid degraded.
  • Mijzelf
    So you exchanged it after your array got degraded?
    Can you see the content of /i-data/168e8bf4 while the system says the disk group is down?
    Does 'dmesg' show any I/O errors?
