I do not find my router model in website
Maryam
Maryam Posts: 1 image  Freshman Member
I have a Zyxel device its model number is "DEL1312-T10B", it is written on the device and in the configuration interface. But I do not found this model in Zyxel website. Instead, I find only "AMG1312-T10B". What is the problem? Is this AMG router the same as my DEL one? I want to update my router firmware and I am afraid the frimware I download is not compatible with my device. Please help me. Thank you
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    Can you see the current version of the firmware? All ZyXEL firmwares have a hardware tag in the name. For the AMG1312-T10B that is AAFP. If your current firmware has that tag, it should be compatible. (And I *think* the router will refuse to flash it if it isn't compatible, but don't count on that)
