Got a problem with NAS 542 raid 5 volume down
Yes to the first and No to the second question.
Here are a some part of the dmesg.17.231207] sd 1:0:0:0: [sda] Attached SCSI disk[ 17.237977] UBI error: ubi_read_volume_table: the layout volume was not found[ 17.239947] sd 3:0:0:0: [sdc] 7814037168 512-byte logical blocks: (4.00 TB/3.63 TiB)[ 17.239955] sd 3:0:0:0: [sdc] 4096-byte physical blocks[ 17.240107] sd 3:0:0:0: [sdc] Write Protect is off[ 17.240115] sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00[ 17.240179] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA[ 17.246780] sdb: sdb1 sdb2 sdb3[ 17.275269] UBI error: ubi_attach_mtd_dev: failed to attach mtd2, error -22[ 17.282302] UBI error: ubi_init: cannot attach mtd222.550744] md: bind<sdb1>[ 22.553795] md: bind<sdc1>[ 22.556943] md: bind<sda1>[ 22.563329] bio: create slab <bio-1> at 1[ 22.567642] md/raid1:md0: active with 3 out of 4 mirrors[ 22.573053] md0: detected capacity change from 0 to 2045706240[ 22.604688] md: md1 stopped.[ 22.614237] md: bind<sda2>[ 22.617448] md: bind<sdc2>[ 22.620470] md: bind<sdb2>[ 22.627298] md/raid1:md1: active with 3 out of 4 mirrors[ 22.632704] md1: detected capacity change from 0 to 2046754816[ 22.864462] md1: unknown partition table[ 22.916251] Adding 1998780k swap on /dev/md1. Priority:-1 extents:1 across:1998780k[ 22.940683] md0: unknown partition table[ 23.049808] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)[ 25.296612] PHY: comcerto-0:04 - Link is Up - 1000/Full[ 25.301883] pfe_eth_adjust_link: PHY: comcerto-0:04, phy->link: 1[ 26.893824] EXT4-fs (md0): re-mounted. Opts: (null)[ 26.920670] EXT4-fs (loop0): mounting ext2 file system using the ext4 subsystem[ 26.931369] EXT4-fs (loop0): mounted filesystem without journal. Opts: (null)[ 27.051251] UBI: attaching mtd3 to ubi3[ 27.124264] UBI: scanning is finished[ 27.139964] UBI: attached mtd3 (name "config", size 10 MiB) to ubi3[ 27.146257] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes[ 27.153095] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048[ 27.159831] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096[ 27.166730] UBI: good PEBs: 80, bad PEBs: 0, corrupted PEBs: 0[ 27.172579] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128[ 27.179741] UBI: max/mean erase counter: 11/7, WL threshold: 4096, image sequence number: 506468069[ 27.188816] UBI: available PEBs: 0, total reserved PEBs: 80, PEBs reserved for bad PEB handling: 40[ 27.197916] UBI: background thread "ubi_bgt3d" started, PID 1209[ 27.336899] UBIFS: mounted UBI device 3, volume 0, name "ubi_config"[ 27.343277] UBIFS: file system size: 3428352 bytes (3348 KiB, 3 MiB, 27 LEBs)[ 27.350618] UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 6 LEBs)[ 27.357779] UBIFS: media format: w4/r0 (latest is w4/r0)[ 27.363627] UBIFS: default compressor: lzo[ 27.367738] UBIFS: reserved for root: 161928 bytes (158 KiB)[ 27.571525] NTFS driver 2.1.30 [Flags: R/O MODULE].[ 27.587374] tntfs: module license 'Commercial. For support email ntfs-support@tuxera.com.' taints kernel.[ 27.597005] Disabling lock debugging due to kernel taint[ 27.610215] Tuxera NTFS driver 3014.4.29 [Flags: R/W MODULE].[ 27.629916] PPP generic driver version 2.4.2[ 27.654186] PPP MPPE Compression module registered[ 27.679288] PPP Deflate Compression module registered[ 27.689135] NET: Registered protocol family 24[ 27.706257] PPP BSD Compression module registered[ 28.020730] elp_register_ocf: Comcerto 2000 ELP Crypto Offload Engine[ 28.027173] m86xxx_elp: Registering key des/3des aes md5 sha1 sha2_256 sha2_384 sha2_512 sha256_hmac null[ 30.366394] egiga1: no IPv6 routers present[ 30.626392] egiga0: no IPv6 routers present[ 39.642350] md: md2 stopped.[ 39.671165] md: bind<sdc3>[ 39.674250] md: bind<sdb3>[ 39.677405] md: bind<sda3>[ 39.684171] md/raid:md2: device sda3 operational as raid disk 1[ 39.690133] md/raid:md2: device sdb3 operational as raid disk 3[ 39.696070] md/raid:md2: device sdc3 operational as raid disk 2[ 39.703076] md/raid:md2: allocated 4220kB[ 39.707188] md/raid:md2: raid level 5 active with 3 out of 4 devices, algorithm 2[ 39.714690] RAID conf printout:[ 39.714695] --- level:5 rd:4 wd:3[ 39.714702] disk 1, o:1, dev:sda3[ 39.714708] disk 2, o:1, dev:sdc3[ 39.714713] disk 3, o:1, dev:sdb3[ 39.714810] md2: detected capacity change from 0 to 11989668593664[ 39.977748] md2: unknown partition table[ 40.073467] ADDRCONF(NETDEV_CHANGE): egiga0: link becomes ready[ 41.134359] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: usrquota,data=ordered,barrier=1[ 41.387414] EXT4-fs (dm-0): ext4_check_descriptors: Inode table for group 0 not in group (block 67108904)![ 41.397119] EXT4-fs (dm-0): group descriptors corrupted!0 -
<div>[ 41.387414] EXT4-fs (dm-0): ext4_check_descriptors: Inode table for group 0 not in group (block 67108904)!</div><div>[ 41.397119] EXT4-fs (dm-0): group descriptors corrupted!</div>That is the same error as you had on dm-1, aka /dev/vg_c1b2735e/lv_168e8bf4. So you can rapair it the same way for dm-0, aka /dev/vg_c1b2735e/vg_info_area.e2fsck /dev/vg_c1b2735e/vg_info_areareboot
Hi MijzelfIt seemed to work, I would very much like to thank you for all the help you have given me, you are simply a superstar0
Hi, I just came to say thank you, I've also had a problem like this, only I didn't actually have a faulty disk at all, nevertheless the logical volumes on my NAS542 were down. Following the steps here helped (after running e2fsck, it took about 5 days to rebuild the raid, but now it's working again). Cheers!
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
