Help Flashing PFSense on ZyXel ZyWALL USG-50
planetaPe
planetaPe Posts: 2 image  Freshman Member
edited April 2021 in Security
Does anyone have experience flashing an old ZyXel ZyWALL USG-50 router/firewall appliance with PFSense (or even some other opensource router/firewall system like OPNSense, DD-WRT, etc)? I can't figure out how to get the ZyWALL to boot from USB.
  • Router is reset to factory settings and updated to the latest ZyXel firmware
  • I have CLI console access over the serial port
  • I've tried a USB stick flashed with the PFSense ISO and another one with the serial Memstick installer.
  • I just can't find options on the ZyWALL to make it boot from USB.
Any suggestions? Is there a way to install PFSense over LAN or over serial connection instead?
  • Mijzelf
    Mijzelf Posts: 3,053 image  Guru Member
    Do you have a reason to think PFSense can run on that firewall? According to the Download Page only amd64 and 'Netgate ADI' are supported.
    Here is claimed that an USG 60 runs a dualcore MIPS. Don't know how the relation between an USG 50 and 60 is. MIPS is not on the download list.
