Why does the philips hue bridge not function when connected to the zyxel but working fine at ...
janoslo
janoslo Posts: 2 image  Freshman Member
Why does the philips hue bridge not function when connected to the zyxel but working fine at Genexis router? I have the zyxel connected to the genexis and WiFi there is turned off. Everything else is working fine.
  • Blabababa
    Blabababa Posts: 151 image  Master Member
    Which Zyxel model are you using and how the Philips hue bridge connect to this Zyxel device? Maybe you can draw us the topology and describe more detail about the symptom "no function"
  • janoslo
    When I changed the system to bridge mode it just worked.
