VMG1312-B10A
spp70
spp70 Posts: 2 image  Freshman Member
Hi
I have a two offices on 3 km distance and want to connect them.
I don't want to use wifi. I can use only phone line (twisted pair) from phone company. They already don't use it and there no signal on it !  Can I use two vdsl modems to get a connection? Or may be i have to use other devices. If there is such devices can you tell me what will be speed between these two points. I know that this depends from quality of cable and if such type of connection is possible at all. I don't need 1MBit/s, 256 or 512k/s will be enough for startes.
Thanks.
  • Hummel
    Hummel Posts: 212 image  Master Member
    edited September 2020
    Not clear for what you are trying to do to connect 2 VDSL modems.
    Can you explain it with more information so that we can clear understand what you expect for?
  • spp70
    I want to connect 2 offices and can use only 1 phone line between them. Phone line have no signal on in it and no other connections. Now It is a "my" private line. Probably there is at lеast one more twisted pair free. I need to convert ethernet from first office(LAN1) by some device (modem) trough phone line and on second office again convert signal from phone line to ethernet(LAN2), and get ping between this LANs.
    Can two VDSL router-modems work this way(peer to peer) on ~3 km distance(without connection to phone company), or some other type router-modems (ADSL or old V90 modems or others if it is possible at all).
    Thanks.
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    edited December 2020
    Hi @spp70
    I don't think that you can do what you want by using 2 off VMG1312-B10D, because they need a partner in the cabinet or in the exchange to talk to.
    What you could do is have a VDSL or ADSL line at each office, like a home or office broadband connection with a VMG1312-B10D at each end, and then run a Site to Site VPN over the Internet between your offices.
    or do it using other Zyxel kit, see https://businessforum.zyxel.com/discussion/551/an-example-of-site-to-site-vpn#:~:text=Creating VPN Gateway-,Go to Configuration > VPN > IPSec VPN > VPN Gateway and,ZyWALL USG 100 WAN IP
    or with Cisco products, see https://www.cisco.com/c/en/us/td/docs/security/vpn_modules/6342/vpn_cg/6342site3.html
    Merry Christmas and a Happy New Year 2021.
    Tony
