Power supply for CenturyLink ZyXEL C3000Z Modem?
MtnDSL
MtnDSL Posts: 1 image  Freshman Member
edited September 2020 in Smart Home Product
Does anyone have specs or an Amazon link to a compatible power adapter/cord for this modem?  I live in the mountains, and lightning strikes keep taking out the power supply (but the modem is fine).  Hoping I can just replace the power supply instead of going through the hassle of CenturyLink "customer service"
  • TiggerLAS
    TiggerLAS Posts: 67 image  Ally Member
    First Comment First Answer Fifth Anniversary
    The power supply seems to be a commonly available unit.
    The most popular model number for the power supply is one
    made by UMEC (Universal Micro Electronics). . .
    Model UP0251M-12PA
    That is a 12 volt, 2A supply, with a center-positive terminal.
    I was unable to find any comments online to indicate
    what size the coaxial power connector is, nor could I find
    any spec sheets or further descriptions of the adapter itself,
    even on the manufacturer's website.
    In any event, both the part number above,
    and generic versions of the C3000Z power supplies
    are all over ebay and Amazon.  At least with US-type plugs.
    Pick up two. . .they're cheap.  ;-)
