Can I use 2 x WSQ50-EU0202F (MULTY X AND MULTY MINI) packs together?
Koocha
I'm asking as I can get that pack cheaper than a single Multy X so hoping I can get a couple of packs and use them all together?
Do you mean you want to get totally 2 Multy X and 2 Multy Mini?
You are able to install them in the same network system.
Please note, Multy mini can only connect to the Multy X as an extender, and it can only be the last node of your network system.0
Please note, Multy mini can only connect to the Multy X as an extender, and it can only be the last node of your network system.0 -
Thanks! I ordered 2 packs and have them all set up0
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
